tdo5h small 16g
SilverGSX95
Nov 28, 2004
haywood, Virginia
What is the max effeciency of a small 16g turbo? I have a fuel pump upgrade and I want to know how much boost is safe?
dont go any higher then 16 on stock sidemount. i was htting fuel cut with my small 16g at 15 psi on stock injectors and ic. with a walbro 255
you can boost as high as you want as long as you dont knock, timing is good, and your/re not maxin out your injectors. small 16g wont heatsoak the stock intercooler as bad as you think.
oh yeah, if you have a small 16g already, then whatever, but if you are planning on buying a small 16g, dont. Big waste of money, IMO. At least get an evo16g to make some kind of power over stock.
