Vegas Smith
- 5,193
- 3,158
- Dec 2, 2002
Houston,
Texas
so a good upgrade for a Big16G would be to purchase a td06 comp housing? and if so, where would you find one? maybe an old 20g housing? would they just bolt up?
Originally posted by DCJ98GST
Jay
So you are saying that the big 16G wheel is efficient but it is matched with the wrong housing. Therefore all these compressor maps for all these various compressor wheels only are right if you use the same housing.![]()
I always wondered why the big16G wheel was so inefficient. I mean damn 71% max is pretty bad.
When we are comparing compressor housing what is significant? The three aspects that I can think of are: the A/R of the housing, the size of the inlet and discharge, and the flow area in the scroll ("A" part of A/R).
but that is a really good idea. i always hear that the comp housing is too small for the wheel. so why dont they start putting bigger housings on? seems like if your hungry....you eat more food.
Originally posted by BoostedTalonTS
Heavy Mitsubishi Industries's Big16G Turbo also comes with a 70mm Dia Hot side, the Small 16G has only a 60mm hot side... Some of the other differences might include a "twin-scroll" intake turbine design on the Big 16, vs the Small 16g, that has the same type of turbine design as your OE 14B, with only a single scroll impeller, not to mention, the same sized Cold side housing as your 14B...
-Happy with my BIG 16G (Porting, NO clip)
Originally posted by ChicagoGSX
Wow most of that post is wrong.
-Twin-scroll exhaust housing is only on the Big 16gs that come from the EVO I-III. The Big 16gs you buy for DSMs have the SAME 7cm^2 exhaust housing, unless you are one of the few with a 6cm^2.
-Both 16gs and all 14bs have the same TD05H Compressor housing. They are just slightly larger to fit the larger wheels of each. The Big 16g wheel is considered by some to be less efficient than the Small 16g.
Originally posted by pianoman
my cousin has a 90 tsi and i have a 90 gs-t we bought them at abou the same time and do the same mods at the same time, we thought it'd be cool just to see the diffrences between the fwd's and awd's. he has a small 16g clipped with 7cm and i have a big 16g clipped with a 7cm. we both have hacked air cans with k&n filters and are running 16psi. my big 16g pulls moderatly harder then his does, but his spools faster.......... now if only i could get 2 turbos one for low end and one for mid to high end.... still workin on that one.
Originally posted by Slowboy
I think you may want to check your measurements.
His feelings are incabable of being hurt
Mike Huml
Originally posted by RamenPride
So you're saying both cars were setup EXACTLY the same??
Anyway, I went with the small 16G.
Originally posted by dcskater82
no not exactly the same, both pretty much stock, except for built motors, 3" exhaust on both, stock fuel shit on both, stock downpipes, no stock side mounts on both...very similar cars, but the big 16 pulls way harder then the small 16....unless the guy with the small 16 messed with someone and ####ed his tuning up? i dont know, but from my experience the big16 pulls harder, thats all im sayin...
