TD05-16G Turbo
Sikes
40
Oct 1, 2002
Need to swap stock turbo, and curious if need to upgrade injectors, or purchase SAFC, and intercooler(other then sidemount), if swap stock turbo for TD05-16G Turbo , yes going to purchase all the listed above , just curious if Better to do all at once,
Sikes
if you keep the boost down you'll be fine
you can run 15psi easy.. Hot wire your current fuel pump. Youll be safe. you could run a little higher psi on race gas if you wanted to. I suggest you get some sort of way to data log, that way you know for sure instead of guessing. everycar is diff.
also i would suggest replacing your fuel filter if you havent done it ina while, to be sure your flowing at least stock levels
