er82
- 247
- 34
- Apr 18, 2014
Sacramento,
California
I was wondering if anyone could give me some pointers with the transfer case for a drag racing.
Here is what I have:
95+ center bearing housing.
1991 iron housing.
F*F brace.
New bearings.
The output shaft (driven gear) measures just about 1 nm of torque (1.43mm preload, and .22 mount spacer), so I think thats good.
But the drive gear measure only 0.25 nm torque. It supposed to be like 1.7nm minimum. I'm using 1.58mm preload spacer and 1.52mm mount spacer. Also, the backlash is just about .004" and attached is pic of contact patch.
Which preload spacer should I use? And should I change any mount spacer to adjust the contact patch?
1991 iron housing.
F*F brace.
New bearings.
