Talon Turbo Help
renzor86
Mar 24, 2010
Winnipeg, MB, Canada
Hi everyone, new to the site and won't let me post in turbo section yet.
I bought a 92 talon tsi. The turbo is a Mitsu TD05H and was curious if anyone here knew what psi it will make and how its is rated 14g,16g etc.
Also needed to know where the coolant lines were connected to in the cooling circuit. Bought car from a friend and have to install turbo.
Thanks.
The stock 1g turbo is a 14b. You should only turn up the boost to what it can handle after supporting mods. The bungs on the forward facing and rear of the turbo are for coolant and the rear one loops under the turbo to the water pipe and the forward facing bung goes to the thermal housing.
That's either a 14B (stock), or one of the [3] 16G's. Look at the part number on the compressor housing on it to tell. The first part is cast, and the part you need to look up is stamped. I know there's a thread on here with the numbers listed.
There are 2 ports on the top of turbo, 1 is coolant and one is supply oil. Is this coolant line supply? On the front face of the housing there is a a port for coolant.
And a reutrn oil on the bottom.
I am somewhat confused with your description.
Can you use this picture and refrence them to lower water pipe and Thermostat?
thanks a bunch!
I checked out that list and my turbo is
49178-05200 small 16g turbo. know if theres a thread or where can i find rated output numbers and stuff?
