2G Talon TSi no fuel no spark
club 598
Sep 19, 2004
wawarsing, New York
hey can some one help me out i have a 1995 talon tsi awd, the other day i was driving went threw 1st to 2nd to 3rd and the car bogged down and stalled.i changed the crank sensor ,computer,and still i have no fuel or spark the car turns over fine but wont start .thanks
are you sure the timing belt is'nt gone???.......make sure the cams are moving, if they are then i'd have to guess ecu is gone or blown fuse check those things....... :dsm:
if the 2g is anything like the 1g, than check the MPI fuse. this will cause no fuel and no spark, on the 1g, its a blue fuse in the fuse holder mounted directly to the pos. battery terminal
-Mike
-Mike
nope.....2g is a different car, no fuses on the pos battery post at all either....... :dsm:
take a test light and see if there is any power on the injectors...
there should be power on one side of the plug. (two terminal plug)
if there is no POWER there then i would seriously be considering a blown fuse or broken wire.
check for ecm powers and grounds also.
does the fuel pump run?
