tach signal wire 5" autometer
compression
1,433
12
Dec 9, 2004
vero beach, Florida
Ive searched , and didnt find the answer i wanted
so where can i hook the signal wire off of the tach? i really dont want to hook anything to the ecu because i have enough cut\spliced\soldered\electrical taped wires down there, i was trying to see if i could hook it to the wire on the coil pack? which wire what color? i tried the black wire on the cas and it didnt work, i know the tach works i had it on my 1.8
thank you in advance
There is a WHITE wire behind the instrument cluster that will test AC voltage. That is your tach signal.
Make sure you test with a multimeter. Also found at a connector above the hood release.
But please test. There could be multiple white wires. :dsm:
Let me know if you need other colors for the car.
EDIT: That is correct for 1G.
for reference purposes, on a 90, its the white wire on the coil pack connector, i think there are 4 wires, 3 black with different color stripes i believe, and one white wire, the white wire is the tach signal wire :thumb: thank you 95gsx
