t25 swap still throwing smoke
darkstar5456
207
Feb 23, 2010
Mitchell, South Dakota
OK so i just finished my t25 swap on my talon and well its still throwing a little smoke. i mean not as bad before i could like a 50ft indian smoke trail behind me LOL but would any one know what would still be the problem. i fixed my coolant leak from the banjo bolt. but i have a little collant from my lower ic pipe i think its still the stock one casue its the rubber. one any idea how much these cost. and how to fix the smoke thanks:thumb:
It is possible that the turbo seals are to blame if you swapped in a used turbo without having it rebuilt first. Also, I would take off the UICP and see if there is any oil residue in the piping as you may be leaking oil into the intake system from the side of the VC (name is escaping me this early) that loops to the intake pipe. It could also be your valve stem seals leaking oil as well. I would also try doing a compression check to check numbers.
