t25 spike no mbc
GotARed
Apr 10, 2007
springfield, Illinois
Today I was installing my boost gauge, and before I installed the mbc I noticed with the stock controller was letting it go 17-18 psi as soon as I banged a gear, every gear.
Does this typically happen, I always believed 11-12 stock was the psi range to be at. So should I put my mbc on or let it be?
Is 18 psi too much for my stock head gasket? I know it is pushing it. Fuel is not a problem. : P
I have an evo 8 BOV and I T'd from the FPR line. We tried two different guages and they both read the same.
Hey bro, I'm not for sure if we are on the same page, but maybe you meant the fuel pressure solenoid line? It is the last nipple on the intake mani on the driver's side. Also, make sure your lines are right. I'm currently on my T-25 and I've messed with it enough that I don't have anymore boost problems... x-( Anyways, factory T-25 T's off of the wastegate... eliminate that. Now you should have a vacuum line off of the turbo and off of the wastegate. The line off of the turbo plumbs straight into the small nipple on the intake by the radiator fan. Hook that line up. Now, grab your MBC. It has a wastegate side and boost source side. Grab some vacuum hose and run the vacuum hose to the wastegate nipple and to the correct side of the MBC < VERY IMPORTANT! Now for your boost source: If we are on the same page, you can run a vacuum hose to the fuel pressure solenoid. This is a great boost source. Works great. It is currently where I have my boost source for my MBC and boost gauge. If you don't want two sources on the same line, you can run either one, your preference, to the "p" port right by the throttle body. Either way, run the vacuum hose back to the boost source nipple on your MBC < VERY IMPORTANT! If it wasn't 11:20pm, I would snag some pics of my set-up for you. I will get back in touch with you tomorrow. If you don't have it solved by then, I will throw some pics up for you. Good luck!:thumb:
JWoodley
Me and GotaRed were preforming this on my car. We hooked it up right, but it was spiking 17psi and holding 15-14 until 5300k without touching a thing!!! And Now it spikes to like 20and falls to 9 : / . For now we just put a line from the aculator tothe boost source on te turbo so its only at like 10psi.
Hmm maybe I should get a CHEAP 14b so I can accually play. But then I got to waste more money on getting it together and on when I will outgrow it in like 2 months.
Ok so please make sure your install looks like this:
For the Boost Gauge Make sure its tapped Here
And make sure your mbc is like this
Set the MBC to the desired boost level
If your still spiking then you might just have a bad mbc
Well if you're on a T-25 then 18psi wouldn't net you anymore more power then you would at 14-15psi. I would set it at about 14-15lbs. After the install it wouldn't hurt to check for boost leaks. To answer your question, 18psi would be fine on an OEM head gasket.
I was spiking to 19 psi with the stock BCS (no MBC) back when I had my T-25 turbo. Honestly, I never got it figured out and I was always afraid I was knocking (didn't have my logger back then).
This past summer I changed my turbo setup to a ported FP BIG-28, a Hallman Evolution MBC, PocketLogger, etc. and now I have no issues. Unfortunately, I installed all that stuff at the same time so I can't tell you exactly what it was that fixed the problem. For instance I don't know if it was the turbo itself, a faulty stock BCS, a bad/expanding vaccuum hose, a stuck wastegate actuator, etc. <-- Those are some things I'd definitely check though!
edit: just noticed your vehicle profile says you have a '91 GSX.. are you sure we aren't talking about a 14b turbo here? The T-25 came on 2g DSMs only.
Stock :( but im working on it. There is talk from my friend if I can find a big or evo 16g for 300 he will give me his small 16g for 100, and I when I do that I am going megan 3 inch dp, and either a cutout with stock catback or muffler shop 100 bucks cat back.
