T04b V-trim, AFPR, 650's LOG...Questions!
iiiwildfireiii
211
Jan 19, 2005
Maryville, Tennessee
I just installed my FIC 650's, 190 lph, and my Import Evolutions AFPR kit.
First off, the IE AFPR kit was VERY nice. It took me a couple hours to get everything setup, cut, and fitted, but EVERYTHING you need is there. My only gripe was the stupid stainless steel hose you have to cut yourself. It is really tricky to handle.
For my fuel pressure, I set the BFP at 43-ish with the vac line off, but when I stuck the line back on it dropped to 33-34 psi. I was under the impression it was supposed to be 38 or so. So, first question, which is more important? Having the fuel pressure at 43.5 with vac off or 38 with it on?
Now, as for the log: This was done at 13-14 psi on a T04b V-trim turbo. Automatic tranny with overdrive on from a 40 mph roll. For the low o2 trims at the beginning I was completely off the gas in order to slow down to 40 mph. How should I tune it? Take more fuel out or up the boost? And how much for each?
RPM Timing o2
2056 28 .32v
2064 28 .10v
2456 28 .06v
2796 28 .06v
3308 26 .06v
3412 26 .06v
4632 27 .88v
5056 21 .94v
5288 18 .96v
5508 16 .98v
5728 16 .98v
5916 18 .98v
6084 17 .98v
6232 17 .98v
6312 18 .98v
6440 19 .98v
6552 19 .98v
6564 -6 .96v (letting off the gas)
4764 9 .96v
4776 12 .96v
