First log with 650's, if anyone wants to help.
adam355
315
Aug 26, 2003
Urban, Wisconsin
RPM Timing TPS O2 1 Bank 1
3059 31 19.25 0.82
3613 30 0 0.88
3313 33 0 0.84
2969 33 43.22 0.66
3078 25 73.48 0.84
2492 22 73.48 0.86
2730 21 79.76 0.88
2930 18 89.59 0.88
3125 16 92.73 0.9
3355 15 93.12 0.9
3625 13 93.52 0.92
3898 14 94.3 0.92
4172 15 94.3 0.92
4445 15 94.3 0.92
4699 15 94.7 0.92
4961 16 94.7 0.92
5207 17 94.7 0.92
5457 19 94.7 0.92
5668 20 94.7 0.92
5926 21 94.3 0.92
6121 21 93.52 0.92
6336 24 93.52 0.9
6539 25 95.09 0.86
Big 16G, fmic, 650s, 16 psi
What do you think?
Its second gear. It was hard to do 3rd gear because of traffic.
3059 31 19.25 0.82
3613 30 0 0.88
3313 33 0 0.84
2969 33 43.22 0.66
3078 25 73.48 0.84
2492 22 73.48 0.86
2730 21 79.76 0.88
2930 18 89.59 0.88
3125 16 92.73 0.9
3355 15 93.12 0.9
3625 13 93.52 0.92
3898 14 94.3 0.92
4172 15 94.3 0.92
4445 15 94.3 0.92
4699 15 94.7 0.92
4961 16 94.7 0.92
5207 17 94.7 0.92
5457 19 94.7 0.92
5668 20 94.7 0.92
5926 21 94.3 0.92
6121 21 93.52 0.92
6336 24 93.52 0.9
6539 25 95.09 0.86
What do you think?
First you need to find out why you are only seeing low 90's for your TPS. It could be various things like your floor mat up under the pedal..aftermarket pedal covers getting in the way, or the actual linkage may need adjusting.
It also looks like you sloooowly put your foot into it. You will get more consistant data that you can compare if you push your foot to the floor at a set rpm every run. No room for human error in how slow you do it if you just mash it.
between 3300 and 3600 you lost some timing so you are a bit lean. throughout the 4000 rpm range your timing locked in at 15 so you could stand to richen that up a bit too. other then that you look cool. I'd turn the boost up a bit as well..maybe 18psi...it looks like your advancing enough to handle it plus you have the inj's and intercooler to handle it (pending other support mods)
