2G Swapping out a T25 for a 16G
Nguyen13
Jan 15, 2023
Del rio texas, Texas
Question but the stock engine that the t25 has if you put 16g in what is the difference affects something?
The things about it is boost pressure is not the same across all turbos. Pressure is a function of flowrate. What we're interested in is the mass of air entering the motor. Simply put a 16g flows more mass at the same boost pressure as a t25. You have a lot of different parameters that affect how a car drives. How quickly it spools. What RPM range etc.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
