Suspension question.....
UNDISPUTEDDSM
100
Jul 17, 2004
NAPLES, Florida
whats up guys, i have somebody willing to sell me some tokico blue with tanabe springs for 250....its a 1.5 drop in the front and 1.7 in the rear.....i was wondering if anyone of u guys are running a similiar setup so i can know wheather a camber kit is absolutly neccesary at this time....or would i be able to go for a lil while with this type of suspension setup...i know in most cases if you go lower then a 1.5 drop thats when you need a camber kit so i'm iffy on the front, and i know in the rear theres a DIY camber kit that you can do.....if you guys have any tips or advice please let me know.....thanks...
You can go for a while with the negative camber but you'll be kicking yourself when you realize that the change in toe has eaten your tires. Fix the rear camber because it's cheap, easy and better for handling. Adjusting the front camber is more costly but with only 1.5 inch drop the negative camber is actually better for handling. But do yourself a favor; make your camber adjustments sooner (rather than later) and get it to an alignment shop.
Can't help you with reviews of your suspension choice.
