Suporting mods?
turboguy_16g
Apr 8, 2011
phoenix, Arizona
Im trying to figure out what supporting mode I need to run a gt35r and how to keep away from ridiculous turbo lag. So far I have a six bolt with forged internals, hks 272 cams, 1000cc injectors.
Cams and injectors are the only thing done besides the internals? If so like posted above you got alot of work to do. Anyways, goodluck sir :hellyeah:
GT35r, Turbonetics manifold, Tial "Race" 38mm, Tial bov, JMF SMIM CFR modified, N/T Trottle body, SBR race-core Fmic, Halmanevo pro Boost controller, Custom 3'' exhaust Afpr, 8an fuel line, Fic 1150cc, walbro 255 intank, walbro 255 inline rewired, Motor mounts
Engine Management:
safcII, gm maft, custom CFR chip or dsmlink
Engine Internals:
JE pistons, Eagle rods, 272's, 3g lifters, MLS, Manley S&R, ARP main and head studs, B/S removal
Drivetrain Modifications:
ACT2900, ACT 6 puck sprung, Fidanza flywheel
This guy ran an 11.6 @ 120mph.
In addition to the parts listed above, I read it as you need info as to help turbo lag so I would suggest making sure there are absolutly no leaks in the manifold/header, mounting the turbo closer to the block of the motor if able to (the heat in the header helps to spin the turbo: more heat=faster spool), a turbo blanket (same reason) and a manual/electric boost controller will help keep the wastegate from "creeping" which dramatically increases the speed the turbo spools. good luck.
