Sunroof
dstarM
69
Feb 24, 2010
Tampa, Florida
okay, so i have a rust spot on my sunroof, and it leaks when it rains, is there a sunroof kit where you can replace it, or something i can put over the rust spot it's prob. about 2-3" wide.
if ## looking for a quick fix just for now you can use silicone. it will do the job. i did that to mine until i have the money to buy a good one
where is the spot? you could make a patch pannel or take it to a body shop... aftermarket sunroofs leak...
it's at the front of the sunroof to the left, i put silicone under the weather stripping, but the water is starting to find its way through again, i'll prob. bring it by a body shop, maybe they can weld on a patch panel like brutal said, shouldn't cost that much right?
  • Wanted 6 bolt NT water pipe
    • chrisman287
