sunroof issue on 2g
Jay D
Sep 29, 2004
McHenry, Illinois
on my 95 talon when i hit about 45mph air runs under the sunroof and you can hear it just hissing away, but if crack a window it will close. my question is there anyway to keep this from happing because on a rainy day water will drip under there very slowly so if u have any advise other than just ride with the window cracked that would rock peace :rocks:
yeah I had that problem,
If you look on the sides of the sunroof from the inside of the car, you should see (if i remember correctly) 6 screws (3 on one side and 3 on the other). They're probobly loose. Give them a good tightening and see how it is. :rocks:
Defiant said:
Oh, sure. Measuring it isn't the trouble. Show me the jig you'll use to keep it there while tightening. Or, show me any measurement on a car body that's within one damned millimeter. :D
I'm a mechanical engineer, if I wasn't lazy, i'd throw something together in Mechanical Desktop LOL.
Mine was doing the same exact thing. The fix? I had to get a whole new sunroof. After the hurricanes were gone, I brought my car to the body shop to get some cosmetic damage fixed. One of the things on the list was a new sunroof seal. They removed the sunroof, and then tried to remove the seal. When it came off, so did the metal strip that holds it in place- it was rusted almost completely away, all the way around.
If it was on my dime and not the insurances, I would have jbwelded it or fiberglassed it or something just to save the money.
Good luck, and I hope the adjustment works.
