Gromit
- 155
- 10
- Jan 24, 2006
metro-Detroit,
Michigan
Got a set of Sparco Stripe pedal covers for my 92 Talon. Clutch & brake pedals were no problem - removed the existing rubber covers & drilled holes in the plates so the Sparco plate could be affixed & then attached the pedal cover. Gas pedal is different - stock pedal is hard plastic/rubber unit attached to a rod via a spring assembly. No solid plate to drill & attach the Sparco plate to.
Only came up with 2 ideas - remove the rod & weld the Sparco plate to it
or carve up the existing pedal so it's small enough to fit behind the Sparco plate but still retains the spring assembly & then attach the plate to it & then the pedal cover to the plate.
I'm sure someone must've encountered this before - any other ideas that might be easier or work better?
Thanks!
Thanks!
