subaru bov into a 1g?
Im not sure myself but I would try and check the 2 gaskets and see if the are the same part number somewhere.Hope this helps.
is the bov flange subaru? if not it wont. people mistake the subaru bov flange to be similar to the 1g, which does look similar as far as the lengh from mounting hole to mounting hole, however the subaru bov flange is actually bigger. it is however big enough to maybe drill new holes to match up with the 1g flange.
