rocafellafw
- 357
- 0
- Dec 24, 2008
Philadelphia,
Pennsylvania
This may be alot to read for some but I'm really lost.
Recently me and my dad went through and replaced all the motor mounts with prothanes, while we were at it we did quite a few changes and upgrades. Before we did all this the car ran fine had none of the current issues I'm about to talk about. After having the car undone for about 2 months we finally got to drive it for the first time yesterday and it was not pleasing at all. First the car idles VERY rich and pulls about 9-12 hg's in vaccum which I know is low. When I rev the car it wants to stall, I have ot keep giving it gas to keep it from stalling. Now to the driving part, the car jerks back and forth, smokes, stutters and is VERY reluctant to make boost. The car has almost no power at all even under WOT it take the boost awhile to hit 10 psi and theres still almost no power, even after making 10psi when the throttle is let off theres not one sound of blow off at all. Now here is the recent changes we did so you can get a idea of what we could have done to make it act the way it is now:
-Replaced UICP with Dejon hardpipes + Moved the HKS SSQ to the new UICP flanged for the ssq
-Replaced fuel filter
-Replaced stock j-pipe with stainless J-Pipe
-Replaced power steering belt
-Rearranged vaccum lines, here is a diagram of how my vaccum lines are ran:
http://img232.imageshack.us/img232/2672/gstengine013.jpg
The MBC goes from the wastegate nipple to the j-pipe nipple.
As you can see nothing to "in-depth" was done to the car, no major changes, but the car now runs like balls. I'm almost sure there is a VERY bad vacuum leak and boost leak. While the car idles I can here the bov whistling, is this normal ? I read you should not be able to turn/swivel the bov around and I can do so very easily so is that a bad leak ? Also by any chance could these be the symptoms of my internal wastegate stuck open ? How can I check and see if it is, reason I ask is the wastegate needed to be removed while working on the car and I think we may have done something wrong when putting it back on. One thing that kind of worries me is we washed the engine according to the guide, we bagged up all the electrical components but could that have damaged anything ? Next we are gonna do a Boost leak test, swap the plugs + Wires and double check all the hoses. Until then does anybody have any ideas on any of the many problems I'm having ???
