stutter problem
wtiger
Oct 10, 2004
Union, Missouri
Hi all new to the board, but not to DSM's. I'm having a stutter problem in 3rd to 5th gear prettymuch anywhere in the boost range 3k-5k rpm's, but it hits most frequently at 4500 rpm's. I've tried new plugs, wires, a different mass, replaced my CAS and adjusted my timing to 4°. any suggestions on the next logical thing to replace? I want my car to be fast again. Also I was trying to get my MAFT to work properly (stutter became more pronounced) and it kept loosing the rpm signal when it would stutter (maybe jolt is a better word); which is why I replaced my CAS; because it pulled the rpm signal from it.
It's a 1g awd
relevent mods
SAFC
removed lower honeycomb and silencer paper thingy on mass
all hard ic pipes
supra sidemount
3" turboback exhaust w/o2 dump
egt, a/f, and boost gauge
pocketlogger
boost controller
FPR set to stock base pressure
walboro high pressure fuel pump
550cc rc injectors
