Stupid newb intercooler question
Demon5spd
90
Aug 18, 2006
omaha, Nebraska
Ok so i just recently bought a 92 plymouth laser turbo about 3 days ago the car runs great besides some of the normal things that i needed to do like replace some cracked vacum lines and do a tune-up but to the question i noticed that the intercooler piping coupler the one that connects to the upper intercooler pipe was cracking bad well go figure with my luck it busted on the way to the airport i put some tape around it and was able to limp it to the airport but my problem is what size is the stock intercooler outlet i want to buy the couplers so when i got home they would be waiting for me oh and and the car came with a upgraded upper intercooler pipe thats 2.25 in's but i'm not sure what the intercooler size is i think it's like 1.75 or 2in i'm not sure any help would be great
holy shit guy, use some punctuation!!!! Seriously!!!
If you want help, list your intercooler size. IE- stock or upgraded smic, or fmic.
Why don't you just go out and take the pipe off and measure it since you will be taking it off anyway? It won't be going anywhere anyways with a busted coupling.
Stock by the way is 2", i don't know if it's helpful or not. Just trying to help.
He has a supra sidemount intercooler, which is in his profile had you bothered to check. If you are going to correct his grammar make sure you atleast have your own down pat and try to aviod
using partial
lines, because
this is really annoying
to have to read
do you know?
Anyways, the supra sidemount has 2.5'' pipes. My advice is to replace both while you are in there.
Right now i'm running the stock supra side mount, and i would go check it but right now i'm away on bussiness ans would like to order the parts now so they'll be there when i return.
