Stroker piston wrist pin height clarification
cherrod8
36
Nov 26, 2009
Hampton, Virginia
Just some clarification on the stroker piston wrist pin height:
Using the G4CS (235mm deck height) with the following:
Eagle 94mm Crank + 156mm rods = 1.65 rod ratio
With the 156mm rods I would need a stroker piston that has the wrist pins moved -3mm, right?
Or
Eagle 94mm Crank + 159mm rod = 1.69 rod ratio
With the 159mm rods I would need a stroker piston with the wrist pin moved -6mm, right?
Please let me know if I have it right or wrong. I had the answer written down before...somewhere, but I can't find it now. Thanks in advance.
