stroker guys need some input please
GstRacer
409
3
May 6, 2003
BooneDocks, Connecticut
well looking at doing the 2.4 stroker kit, well just wanted some advise from anyone that has it about how they like it, don't like hows the longevity, exhaust tone, power, street driveability. any input negative or positive also I'm FWD if that matters to any of you thanks a lot
The 2.4 is a great motor if you are looking for the extra umph. Depending on which stroker you go with they are capable of between 600-800 whp with the correct supporting mods. With a 2.4 you will also increase your turbo spool up. This, in a matter of opinions, could be good or bad for FWD. More hp and quicker spool up means more wheel spin. However if this is a track car, with a good set of slicks it is possible to get awesome times with the right mods. What turbo are you looking to run? Also is this a street car, street/strip car, or strip car?
Exhaust tone depends alot on exhaust...with a 2.4 is is usually a little deeper than a 2.0 but not alot of people notice. Driveability depends alot on the rest of the set up, clutch, turbo, ect. Hope this helps a little.
  • Wanted 6 bolt NT water pipe
    • chrisman287
