Stoker kit
rmenaul
52
Dec 30, 2003
Toronto,
I'm doing a rebuild in june or july... need some opinions on this stroker kit and whatever else I might need.
Included in the kit .
Remanufactured crankshaft
NEW main and rod bearings
NEW Wiseco 8.8-1 pistons ( Coated Skirts ) .040 / 1mm oversize
NEW Wiseco piston rings
NEW Eagle rods
(About $1300)
Any thoughts on this kit?
plus I'd need cams/camgears
Anything else???
95TalonTuner said:
reman'd cranks are a bad idea.
you do understand you need special pistons for a 2.3.
Well this kit includes the pistons listed... would there be clearance issues or any issues?... how much would it cost to go with a 1g 6-bolt?... here are the two kits:
http://www.carshopinc.com/product_info.php/products_id/59249/CS23KIT2
http://www.carshopinc.com/product_info.php/products_id/59245/CS23KIT
any thoughts???
I've heard to go the 6-bolt way, but what would i need for the swap?, how much would it cost?... anyone done it?
Thanks in advance for any opinions.
6 bolt swap is definately the way to go and theres probably like 10000 threads on it, very common and very good swap. search and learn
I'm having trouble finding a local place that can do one?... anyone live near the GTA?... how much should it be? (I'm assuming you US guys will quote american currency)
You should contact www.engintecs.com . They are a kick ass machine shop in Chicago. You should not use a regrind especially on a stroker application, and guess what Mitch at engintecs only uses cranks that are new or well with in specs. :thumb: (He offers excellent prices on new cranks and stroker kits). :thumb:
