Stock tune setting
Unplug it and pull the battery cable and you should be back to factory setting...it will be ok as long as you have stock injector which you do right?
set it at 10-12psi until you get some more supporting mods. Are you running your BOV recirculated back into the intake?
When I had a Greddy RS I had to adjust it pretty soft so it wouldn't flutter. Every car is different. But my guess is that you'll need to make it quite a bit softer if it is adjusted all the way to the hard setting.
It's a mess. It should all work, but I'd completely redo it if I were you and had the $5 for some new vacuum hose, it has WAY too many T's for me.
I'd set it up like this:
BOV > IM (you have 1 T here but it looks like it's capped?)
WG > MBC > Compressor Housing Nipple (I see 2 splits on the MBC line going to the IM, looks like it shares the line with the FPR-S and possibly a boost gauge?) I'd actually just pull the MBC and go back to the BCS with the restrictor removed.
IM > FPR-S and boost gauge (here's a good place for a T)
Vacuum hose is cheap, and searching for vacuum leaks is a headache, especially with so many connectors and splits. It'll look nicer, be easier to diagnose, and less prone to leak/blow off. Zip tie your connections when you're done.
Thank you Broo thats what i been looking for
