NeMiZiS
Supporting VIP
- 2,116
- 51
- Jul 25, 2007
Palmer,
Alaska
When I installed my throttle body, I noticed a huge difference in the higher RPM range.
Pretty close to a true statement,So no matter you do to a 420A as long as your not adding a turbo, or nitrous etc.
There will never be a need to install larger injectors?.
When you go over 200whp.I'm really not trying to argue, it just seems like at some point you would want bigger injectors.
what would be the min sized injectors i would need for my set up then because im sure i will makeat least 175whp when ever im done with my build up
well the 420a comes with 140 stock and you should beable to get about 175 180 at the crank with just simple bolts ons (exhaust cold air intake) so i figured with a high compression rebuild and other supporting mods to keep it n/a 230-250 at the crank shoud be achieved so thatwould be about 200-210 at the wheels
I understand that you are asking the question, not questioning the answers.
At around 175whp I was at the point of going (at the highest point) to around 87% duty cycle on stockers. I know many people go into the 90's and higher, but for the sake of accuracy and heat, I don't like going over the low 80's. So at that point I decided to go with the 450's. With those, I am now in the 50% duty cycle of the injector.
As far as size of injectors, I believe somewhere they are listed as 190's but I know for a fact that a couple of us have had them tested at 225 to 230 (depending on who tested what. Mine were tested at 230, as I recollect).
To the OP, stick with the stockers,
MB
What are you saying? That I finally beat you to a postAhhhh
I was just going down the posts in this thread hitting the multi-quote button, until I got to this post.
). So if its open 90% of the time, then you would get more fuel through, than at say 50% "duty cycle" (for the same injector).
). Therefore you could get a lot more fuel being dumped into your engine if you upgraded to bigger injectors because your ECU is expecting the injectors to still be the smaller size and it is making adjustments under that assumption.
Let's see if I can explain, kinda simple like, about injectors sizes etc.
First off, injectors by themselves give you no more horsepower. What a larger size injector allows you to do is put more fuel into your system (IF you can use it/need it). There are lots of other things that come into play, but lets just stay on injectors.
So (with fuel pressure staying the same) the amount of time an injector stays open, regulates the amount of fuel that goes in the engine (open longer, more fuel can go through). The amount of time open is called the "duty cycle" (the time the injector is doing its duty,). So if its open 90% of the time, then you would get more fuel through, than at say 50% "duty cycle" (for the same injector).
So now, with different size injectors we would have different size openings. Lets take a hypothetical 200cc injector (it has a nozzle set-up that allows 200cc of fuel per minute) and compare it to a 400cc injector (double the size capability at 400cc per minute). So, in theory, the 400cc injector at 50% duty cycle would give double the fuel than the 200cc injector (approx guys, I don't want to discuss opening and closing ramps and dead times etc.). Therefore you could get a lot more fuel being dumped into your engine if you upgraded to bigger injectors because your ECU is expecting the injectors to still be the smaller size and it is making adjustments under that assumption.
With our cars specifically, we generally run rich as it is. Adding fuel with bigger injectors and no modifications or tuner adjustments (ie MSnS) will only waste fuel and could actually lose power.
Now in DSMTriad's case, he has added adjustability to his equation so he may get something out of his upgrade.
The question becomes, what is your car going to do with that extra fuel? With our cars and the stock ECU; not a helluva lot.
IDK, I just re-read this. I hope this makes it a little easier to understand
MB
. If you get bigger injectors know you'll have one less thing to worry about in the future. But remember this what i would do. If your gonna turbo it in let's say a year don't get injectors but if your gonna turbo it in like 2-3 months then yea get bigger injector's.
. I'd wait for a wiseman to reply back to that sorry i couldn't help.The definitive answer is ....NO. NO you will not have a problem with your build and stock injectors. NO you don't need bigger injectors. NO you will not get more power with bigger injectors NA.i dont plan on goin turbo for a while. if i keep the stock injectors would i have any problems if i do the build im wanting to do or will i need to back off on something like getting stage one cams versus stange 2 or keep stock compression versus 10.5
