stock maf in IC track?
JessesTalon
2,409
4
Dec 13, 2003
Beaverton, Oregon
Can this work?
I mean the maf-t can be in either place, intake or IC track... what if you modified the stock maf to fit into a shape of IC pipe? could you run vented "correctly" this way and get a little quicker spool-up.
Nothing was found in search had to nit pick a ton of unrelated threads until I finally gave up and posted this.
It works with the MAF and not our MAS because they meter air differently. The stocker will not work in blow through design.
I've had a maf-t setup on my last DSM. I was just wondering if it was possible, thanks for answering the Question guys.
As I said I did search but couldn't sort through hundreds of unrelated threads as this isn't a common topic and after going through pages knit picking threads found nothing to answer this Question.
