stock lancer evo parts on 1g 4g63 motor
hiimt0ny
70
Mar 25, 2005
new orleans, Louisiana
i was wondering if anyone knows what stock lancer evo 8 parts would fit on the eclipse..... like for example would the 550cc injectors from an evo8 work on the 6bolt eclipse engine or would the head, cams, or intake manifold bolt onto the 1g or 2g motor of an eclipse talon or laser??? they are both 4g63 motors correct? so what parts from a lancer can be upgrades on an eclipse??
I injectors would work with supporting modifications. although i think there 510cc not 550cc injectors. I could be wrong.
The head will not. The evo engine is turned around (to an extent). the transmission is on the drivers side. The intake is flipped around also. wich could be worked out also except for that fact that the timing belt is obviousley oppisite of the transmission. Its on the passenger side. Im not sure if the bolt pattern is the same but it dosent really matter after you realize that even if it was it wouldnt work. just do a image search on google for evo8 engine and you see.
sorry for spelling the spell check isnt working and i cant spell worth a hell.
what about the cams and cam gears? wouldnt that be a cheap upgrade for us? and some evo injectors are 550cc injectors stock and some are 510cc.
