stock head gasket information needed
Why do you need to know the thickness? The bore is 85mm, if you need a new one, just get an OEM replacement.
i was just wondering because i need a new head gasket. i decided to go with a composite felpro gasket because im doing a mild full rebuild with new ARP head studs. i went with the felpro composite because i didn't deck the block or the head
ya i probably should have if money was no option but because there was no problem with the top end of the car and it had great compression across the board before i took it apart i believe it will be ok the machinist at the machine shop said that it was perfectly fine
