stock gsx ecu tunable ??
Open your ECU.
If you have a large black chip in the lower right corner (with connectors upwards) you can change that EEPROM chip with the one of ECMLink (v3summary [ECMTuning - wiki]).
If not they are able to modify your ECU to accept that chip.
Or you look for a 2g FL ECU - this one is flashable - and do some rewiring
Or you choose an Evo8 ECU - more features - and some rewiring needed as well.
Right injectors for what? 300crankHP or 800wheelHP?
for injectors:
RC Fuel Injection
EDIT: if you plan on running E85 you will need 30% bigger injectors ;)
All depends on what your looking for, stock turbo? There are a lot of smart people on here, just give more details about your car and they will help you out.
hey man seen your car on craiglist! but for tunning if you don't have an eprom and you want to save money I would go with a 98-99 black box and get that flashed it would save you a lot of money and you can almost do just as much with link. If you don't mind spending the money then I would for sure go with link.
And for injectors on a stock turbo. I wouldn't really worry about that unless you plan on going with a bigger turbo.
