Stock fuel pressure at 52 psi
idt512
231
9
May 4, 2003
Hemet, California
I spliced into the line from fuel filter to fuel rail inlet and Tee'd in a pressure gauge, and i get 48 psi with the FPR line connected, and 52 psi disconnected. It is a stock fuel regulator and the car runs and drives perfectly fine. Should i correct it or leave it alone?
The gauge i used was from a pneumatic air pressure regulator from my work, the regulator portion broke and they were going to throw it away, the gauge was functional so i figured it would be ok to use... Does it have to be a FUEL pressure gauge?
This is happening with the OEM fuel pump. I know my profile says Walbro 190 but that was from a car i had years ago and im unable to change my profile.
Is the location of where the gauge is placed critical? Does it make a difference if its placed BEFORE the fuel rail? The aftermarket AFPRs are AFTER the rail and im wondering if the reading would be skewed because of that.
