Stock DP heat sheild question
T is for TURBO
2,250
25
Jan 15, 2005
Milwaukee, Wisconsin
So my car has been raddling like crazy the last few days, and only when the car was good and warm. I was confused as to what the raddling was comming from and it only happened at idle... Finally one day, after the car was off i shut the door and heard the rattle. I just figured a loose heat sheild or something along that line, and sure as shit, about ten minutes ago I took a look under the car while it was running and the heat shield that rests on top of the stock downpipe is no longer attached, its just chillin like a homie on top of the downpipe. My question is... should i replace it, or should i just remove it? Could the heat damage anything if the heatsheild was removed? I figure its there for a reason... but I also figure most aftermarket exhausts don't have it... suggestions?
Thanks
-Shawn
My lower heatshield has no chance of fitting over my RNR o2 elim. so I ditched it about 2 years ago, it's been fine for that much daily driving plus about 100 1/4 mile passes.
I know most everyone with an aftermarket O2 housing don't have a heat shield, but I believe the top 2 causes of alternator failure are leakage from the PS pump and heat from the O2 housing.
Just food for thought.
loose it, but make sure you have a heat shield on the manifold, too many things get broken when that sheilds not on.
Word... I didn't have my heatshield on and my manifold got so hot it completely melted the fan blades on my ac fan. When they broke off and scattered under the hood I thought I threw rods, freaked out pulled over and found what looked like birdshit stuck on my manifold and figured out after 10 minutes of screaming at my car and a ton of F words that it was in fact melted fan blade. LOL
