spyderturbo007
DSM Wiseman
- 2,425
- 59
- Dec 20, 2002
New Cumberland,
Pennsylvania
Everything I read says it is, but i'm not so sure.
I was previously running about 33lbs/min with the stock cat back at 20psi on an EVO III 16g. The stock cat back was coupled with a 2.5" DP and 2.5" high flow cat.
A couple of weeks ago, I upgraded to a Greddy EVO 2 cat back, HyperDrive C1 Clutch and a CoolingMist MeOH injection. With the boost set at 20psi I made a couple of pulls and the airflow was.........you guessed it, right about 33lbs/min. It varied a little bit, but nothing appreciable.
So, I'm really thinking that the stock cat back isn't really a restriction since I don't see any other bottle necks in my system.
EDIT -> Oh, and there aren't any boost leaks.
