stock 02 housing w/ 20g?
OnlyNeed4
56
Dec 17, 2003
port huron, Michigan
I was just wondering if you need to change o2 housings when using a 20g turbo or if you can stay with the stock one. thanks
No, you do not need to change it b/c its a Mitsu style outlet flange. Like this 1st pic here. Other options w/ turbo's can have a T3 style outlet flange seen in pic 2. See how the bolt holes and flanges are different? This doesn't mean that only mitsu turbo's (14B, T25, 16G, 20G, 18G, etc.) can only have this flange, turbo manufacturers build turbo's w/ the mitsu style flange for direct bolt in replacement turbos for easy of install and so you don't have to buy a new 02 housing too!
Hope this helps, Dan
