still having prolems with vibration
gsxspeedlab
127
Apr 16, 2002
well i posted a while back about a bad vibration i was having and a lot of different suggestion were given for possibilities. well i just got my clutch changed out and it seemed to help the problem quite a bit. and it doesn't occur at 3k rpm anymore. it does it closer to 5k rpm and it's not as bad. i know it's not a timing issue, BOV, EGR valve, exhaust problem, clutch problem, cam problem, blah blah blah. i've checked a lot of stuff.
anyway, my question is, what else should i look at? all help is GREATLY appreciated here.
i'm running low on ideas here. :confused:
if it were any of those, it wouldn't do it out of gear. i can rev it up and get the same vibration. it's about 90% gone though, since i've got the clutch fixxed. i can hear my turbo spool up and my BOV go off. i couldn't before. my clutch was down to the rivets when i got it replaced btw.
