Pirrofab
- 726
- 40
- Sep 2, 2006
gouldsboro,
Pennsylvania
Took the car to the track the other day and noticed that boost kept climbing past 20 with my 14b even with the mbc set to 15-16psi. I continued to turn down mbc and boost still went to 20+, I then removed mbc and ran direct wastegate from j-pipe. Boost held steady at 10psi for about half track and then would start to climb to 20+ again. Wastegate actuator seems to move freely but does require effort to pull out and also holds vacuum. I've never experianced this before and the exhaust has been on my car for about a year. If its any help I did a boost leak test the night before and fixed a few leaky vacuum lines and b.o.v flange. I have a few other issues but I will post them in other threads to avoid confusion.
