Stereo Install
TinyGoliath
44
Jan 28, 2015
Grand Rapids, Michigan
So I know I am going to get some heat for this highly asked question. the 96 Talon picked up recently had the stereo jacked out of it. Now I have spent about an hour reading threads and going through Vfaq. The car has the Infinity amp under the seat and the harness was not cut(Thank God for respectable thieves). Now If I buy a new single din head unit, door speakers, sub and amp, what is the right way to hook it up? I don't want to use the infinity amp as the head unit has enough power for the door speakers. The speakers have tweeters so I don't mind losing the dash ones, the amp I would use to power subs only. I would like to get by without running new speaker wire to the doors. Is there a plug-n-play harness that will allow me to run the new head unit/doors without the infinity system? I know this has been posted a ton but looking for one clear distinct answer.
TL;DR: Putting in new System, Don't care about tweeters, don't want Infinity system, plug and play harness for new head unit?
Figured I would hook up the system now because I am waiting on a new Boost, Wideband, oil Pressure, and Volt Meter to come in and will just wire everything in one go.
I just put a radio in mine (1996 eclipseGSX) and all that the amp ran was the dash tweeters. I was able to get a jumper harness for the chassis and just tapped into the harness at the amp for the dash tweeter connection. With putting in the single din unit all you need to do is wire the correct colors from aftermarket unit to proper colors for OE speaker location.
Did they cut the harness off the radio or actually unplug the old unit?
I do not know what unit was in previously, only that is was ripped out, the mounts and trim are all mangled yet the harness was simply unplugged.
Thanks guys! Anyone have an exact model of a 6x9 shallow enough to fit in the rear without modification?
anyone know what this is?
Ah. I should have figured. I was just thrown off by the 15 yards of cable wrapped up under there. Thanks
Ok. Just in case anyone in the future is wondering, I got the install done, with infinity system. I got a Metra wireing harness 70-7001.
http://www.amazon.com/gp/aw/d/B0002BG6DM/ref=ox_sc_saved_image_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
This was perfectly color coded, the stereo I got Sony cdxgt270mp
http://www.amazon.com/gp/aw/d/B008V9934G/ref=ox_sc_saved_image_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Did not have a dimmer option so I left that capped off. But the wires color matched besides that.
The front doors are 6.5s I found that R615x3 from Rockford fit well, I did drill my own holes into the plastic mount but it was really close.
http://www.amazon.com/gp/aw/d/B00BF6HWCM/ref=ox_sc_saved_image_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
In the back was 6x9s. The common issue was that the wheel well makes the mounting depth shallow. MB Quart makes a set that fits( really snug, but they fit when screwed in)
http://www.amazon.com/gp/aw/d/B00C86N6FK/ref=ox_sc_saved_image_2?ie=UTF8&psc=1&smid=A1FMHNVWMGI839
Everything fit plug and play minus my adaptor from scoshe, it needed some cutting to fit and did make it, but there is a gap at the top and it looks bad.
http://www.amazon.com/gp/aw/d/B0007KPRYW/ref=ox_sc_saved_image_5?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I couldn't find a better one and I was disappointed with this one.
Otherwise everything went in well and it sounds great without having to touch anything with the infinity system. No bypass, no new speaker wire, and it works great all for about 145 dollars shipped from Amazon and they are all prime items if your a member for free shipping.
Thanks for all the help!
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
