Starting Upgrades
canadian95GST
Mar 4, 2004
Lethbridge,
Hey, I am just new at this and just recently bought a 95 Mitsubishi Eclipse GST. I'm wondering what stuff I could do, to get sum good HP. I have a 3" APEXi downpipe and an underdrive pulley, but just need sum ideas on what else I should do before certain things. Thanx for your time!:dsm:
Welcome to the "DSM Family" The "The tuning Guide" is the best way to go,everything you will need is there step by step,you can't go wrong with that.Just my 2 cents.Later!
Those are good stages to start with. Some should be grouped together and some should come after others. For now getting into performance go with a boost gauge and pod (dual or triple cause you WILL get another one eventually). I hope you have one since you already sport a mbc :confused:
On the underdrive pulley, I hope it is not one that bolts to the crank, since the factory pulley is a balancer as well. For a FWD I recommend either the Prothane or Windo weld motor moutns before makeing serious power. They are cheap and help termendiously (SP?) with wheel hop. My major power gains were, Upgraded turbo, Downpipe/ exhaust. I would however follow the 2G upgrade path on the DSMtuners homepage. Just keep you suspension in par with power since you are FWD.
Welcome to the club
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
