Starting Project Soon
welfle18
474
Sep 14, 2006
Norwalk, Ohio
Parts waiting to be put on the car.
Gaskets. OEM composite headgasket, ARP headstuds, BC springs and retainers, new valve stem seals, AEM UEGO.
Parts needed yet.
Cams (delta regrinds still unsure of the duration that I plan on running), HX35 8 blade from Justin hopefully(jusmx141), some turbo hardware from ffwd, BEP turbine housing.
272s will be more than enough. You seem to have the same list that I'm compiling.
Good luck getting traction on the FWD if you plan on pushing that HX to its limits.
Stock 7 bolt? What clutch are you running?
Well I am running an act 2100 right now with the street disk and an act lightweight flywheel. I know that it prb wont hold all that long but being fwd hoping that it will last a little longer than if I had awd. I am only planning to run the holset to about 400 hp till I destroy my bottom end then when its rebuilt push it to its limits. Traction is my next set of plans if the motor holds up long enough. But I plan on doing a tein coilover setup when the funds are right. And since I am keepin my stock rims for somewhat of a sleeper look I am going to up my brakes to the 1g big brakes. We'll see how long things last though.
New parts I can add to the purchased list is the set of cams, kelford 272's, turbo hardware from ffwd along with a egr and a fiav block offs.
