2G Starter Wires
PhatEclipseGST
44
Mar 15, 2005
ADAMS, Massachusetts
Ok im putting my car back together from a clutch install... i need to put the starter wires back on... there is one thyat is black with a yellow stripe that is fairly large middle opening... Does that ground to the tranny? And the other one which has a bend on it... does that go to the lower bolt on the starter???
The starter has a black clip that clips on and i need to figure out what goes on the bottom bolt... then there is an extra wire maybe it goes on the rear mount instead of the tranny... i dont know my friend took it apart and im getting pretty frusurated... ANYONE HELP?
thanks
on my car (should be the same as yours since yours is the turbo 2g) i have 3 wires. i have a black and yellow wire that has a circular opening on the end that goes on the upper bolt on the tranny that bolts into the starter. there is another wire with the same kind of end, but is bent 90 degrees and has a red cap on it, that goes on the stud comming out of the starter and has a nut to go on the end of it. i also have a small black connector that has a small slot in the end of it that slides onto a small metal tab next to that red commector.
I thought the starter only has 2 wires connected to it... There is that clip and that stud/bolt below on the bottom...
