starter location
If you get one of the hayes or chiltons book they tell you how to remove it. And don't be afraid of it it may look like a PIA but it is very easy.
in the hayes manual it says to remove the air cleaner ? WTF? i guess they meant intake manifold
You do not need to take off the intake manifold. It's 2 bolts under the intake manifold on the bell-housing of the transmission. Take out your battery and it will help alot.
I have never taken out my intake to replace a starter. It may have said to take off your intake pipe as in intercooler pipe. But you shouldn't have to. Just find the starter and move whatever is in your way.
just undo the bolts from the top. It is much easier that way. take off the upper IC pipe and move the batter and you'll be fine. Much easier than trying to unbolt it from the bottom. Undo the two bolts from the top, pull it out from the bottom.
best of luck.
I just replaced mine last week, I took it out from the top and I didn't have to remove anything else to get to it, it took me about 25 minutes to remove and replace.
