starter issue
smgs92
Apr 19, 2011
milford, Ohio
Well my car wont start, and it wont crank over the starter doesn't do anything like if the battery was dead. But the battery is fine I was gonna replace the starter but I was gonna make sure that's what the problem is. thanks
Replace the starter first next time..Then if it's not the problem make a thread about it..We can't give you any insight if you didn't replace the starter, and it still won't crank..
i replaced the starter and it still wont crank or do anything i have checked and the battery is good my friend said it might be my fuel pump because he said his truck wouldnt crank when his went out but i dont get why it wouldnt crank over so idk
Did you check the blank w/yellow stripe wire? There is a connection to the harness usually under the thermostat housing... How about the fuses under the hood?
where is the starter solenoid located? i cant seem to find it
and it will push start
Is you car a 5 spd? I had this issue once and i had to unplug the neutral safety switch (something along those lines) Its just a small white connector just up under the dash where the pedals are. I'll post a picture later tonight if you can't find yours. Unplugging this connector also allows you to start the car without pressing in the clutch (only do this while the car is in neutral though)
The starter solenoid is attached to the starter. Try tapping the signal wire off the starter (small thin wire) to the battery.
my neighbor had told me there was 2 starter solenoids apparently its only on ford and we didnt know
and i dropped it off at a shop to be checked out and ill probably fix it myself
Here's a picture of the neutral safety switch I told you about. Try unplugging it and see if the car starts up before spending money on a mechanic.
already took it to a mechanic it took them 5hrs to figure out that was what it was and im just gonna have em replace it for me since its already there and id have to order it from the dealer anyway its pretty cheap anyway
