Starion intercooler [Merged 9-7] FMIC front mount conquest
Don't bother, take the 100 bucks, and buy the Dejon tool upgraded SMIC. It flows ALOT better than the starion IC does. Trust me I KNOW i had one and it sucked. Not worth about the $300 you will spend on the intercooler, modding it, piping. Good luck
Got any data to back up the statement that a Starion FMIC sucks? It's been used as a performance upgrade on T/E/L's since day one. It is much better than a stock sidemount.
I put mine together for less than $200 including all the piping (http://www.vfaq.com/mods/StarionIC.html) and put down 252 WHP (about 290 motor) with the 14B and I've been driving it every day for 4+ years with no problems. It's not a race piece but a great , low cost, street upgrade, especially if you like to build things yourself.
Always do your own research and compare opinions with fact. :thumb:
Rick - '91 GSX :dsm:
i was thinking about the starion/conquest thing. But ive heard way to many bad things about it, crappy flow, pressure drop, end tanks and its a hack job. Ive heard better things about the supra thing, but its still a big hack job. I would just go with the cheaper Dejon tool stuff if your on a budget, they have a cheap yet good SMIC and FMIC dont they? one of there front mounts is just 2 rebuilt stock cores with better endtanks and stuff i think. I was looking at the Greddy one, its only like 800$ or sumthing with pipes uses stock pipe location and stuff....
http://www.extremepsi.com/x/customer/product.php?productid=16188&cat=306&page=1
do back to back runs with the stock ic and stock piping vs your setup now. tell me which was faster ;)
id rather crap in my hand than put a starion fmic on my car.
OK I dont have the funds to fork out $600+ for a used fmic so I thought these would be my best choices for the $500 and less category. Which setup would be more efficient? This would be for a 14B running 16-18 psi
For the smic, I know of Dejon and ADFX... what other brands are available?
How about save your money for another couple months and do it right the first time?
Regards,
Hey there are 2 great guys here in Oregon can build you FMIC + Piping for cheap.
Talk to Animosty4G63 (DJ)
Or if you want really cheap, get a supra SMIC and get that piping for it...
Alright smartass. I was giving you an honest answer because you won't be happy in the end with either of your choices. If you want to be an ignoramus, then go ahead by all means, waste your money. Have a great day....
Regards,
Regards,
Very true, save money and do it right the first time...
look at his rank, DSMTUNERS WISEMAN... :p listen to the wise people
Guys, no need for insults…
idt512, you might not like the manner in which NosLaser replied, but he is right. Starion I/Cs are hardly an upgrade over 1G or even 2G side mount I/Cs.
Front Mount I/C can be a good upgrade, but Starion is not a good way to go… I/C cores are not all that expensive. By the time you get done welding proper inlets/outlets to the 88-89 “big core” Starion I/C (86-87 “small core” are not even worth considering…) you will be well on your way to paying for a “real” core.
Plus, good I/C piping is NOT cheap and it is one the most important parts of the I/C kit!
I will second NosLaser’s advise: Save your money for a REAL I/C system…
Leon
RR
Correct or not, he was being a real jacka$$ about it. The question was which is better between starion and SMICs?
Are you implying the Starion setup is slower, like I was making MORE than 290 HP with the stock SMIC?? No way, it's much improved. Like I said it's "a performance upgrade". Check the VFAQ and the old Talon Digests see how many guys ran Starions with marked improvements. I'm not saying it's the best FMIC just a good alternative to spending big $$. It works.
Now why would anyone post an idiotic statement like that? :confused:
I wasn't being a jackass you child, I was giving you advice from someone who has much more experience on the subject than you do. You got upset because I didn't give you the Fast and Furious answer you were looking for, but instead I gave you good, real advice. I will say it again. You will be wasting your money using a band-aid fix when instead you could save your money and get a setup you'd be really happy with. How old are you? You must be a kid, because kids know everything.
Regards,
You've got valuable answers from experienced people . They are tying to give you a hand so you will do it the right way from the beginning and actually end up saving money but you jumped to bite that hand.
This is why DSMs need constant maintenance and repairs. Guys do things half-way but than they expect the world from their poor cars so they and up "Cry-Cry-Cry".
Try to appreciate somebody's effort to answer your questions and if it's not what you were looking for express yourself nicely.
This forum shouldn't be a battlefield .
go tell phil beers that.
starion has more surface area, less flow. you will get similar results if you just mount your smic in front of your radiator. plus you could call it a fmsmic, and then confuse everyone.
anyway, they are right, dont waste cash on the starion it pretty much sucks.
Hey, I am wanting to know from all you 2G Starion FMIC users, just HOW did you mount your intercooler, and piping also. I am looking for a few pics and a little info on how you did it. I have a 99 Spyder GS that is getting the whole treatment with turbo and head swap! I am using the stock GSX turbo whichever one it is, the T25 or TD05. I will post pics here later.
What are you trying to do?
Why did you just not buy the hanh kit?
Corey-
Because he doesn't have a 420A motor. Go to the vfaq, there is a write up on how to install a Starion FMIC there.
Thanks, I found a way to do it with the dimensions of all the piping used and how to cuz and weld the IC to look clean. Sorry to post this again if it already in the VFAQ's. My bad
