stalling after hard drive..?
EuroGSTSpyder
1,171
Feb 18, 2002
Stockholm, Europe
Ok my car has gotten the stupid thing going....never had this problem before
If I go out driving..and step on it alittle...then when I let go off the gas it stalls sometimes. I am not venting BOV and I have never had this before. I dunno even where to begin really....Any ideas?
1997 GST Spyder
B16G all supporting mods(inj,pump,intake,filter,3" system ,mbc etc)
It doesnt happen all the time but often enough to piss me off!
what kind of bov do you have. i had a similar problem with my turbo xs but it was just the valve getting stuck open a little. a little white lithium grease and the problem was solved. also when i changed my vaccum lines they weren't solid enough and it blocked air flow. check the vaccum hoses. other than that i can not honestly say.
Have the Greddy Type S wich I had all along. Maybe something happened to it when I presure tested my IC system..? Might have t check that cause it never happened before that test....
How much should the Type S hold by the way?
All the hoses are fine as far as I had time to check..need to check again tomorrow in the garage.....
ok put the blow off valve to side cause its not that...... Check your cable and your plate behind your intake manifold, your throttle cable is to loose right now. tighten it up and re-adjust the biss screw on the tb
i also have a 97 gst spyder i have been haveing the same damn problem and i cant figure it out....but also check your EGR and EGR solenoids..i heard thats sometimes a problem and i also have the greddy type s...i just cant figure this thing out..if anyone knows or if u figure it out let me know ...PLLLLLEEEAAAASSSEE :cry: ..sorry ...its sad for me :dsm:
  • Wanted 6 bolt NT water pipe
    • chrisman287
