stainless clutch line problems
4g64GST
197
Jan 29, 2004
Dallas/Fort Worth, Texas
I purchased a goodrich ss clutch line and it sucks. It is to long and I have to zip tie it out of the way. Then when I bleed the line as soon as it starts getting pressure in the pedel it blows fluid every where. It wont make a seal. Plus why use a banjo on the slave when you could just have a fitting that screws directly in to it. So I just went and had a custom ss line made.
anyone else have a problem or just me.
Most ss clutch lines replace only the stock flex line that runs between the hard line attached to the chassis and the hard line attached to the slave. Yours also replaces the hard line to the slave? If it uses a banjo fitting it should also have copper washers on the fitting.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
