Stage 0 mods.... now probems
You can't just pull the lines, you need to know what to cap, and run different and eliminate.
It's not that easy. . . Look up the taboo guide to vac elim, that will help.
I simply removed the 4 vacuum lines on the TB and capped them (I KNOW THERE NOT LEAKING).... The smoke MIGHT not be realated but WHAT else would cause minimal white smoke??
Why don't you try putting everything back together and seeing if it still smokes after that. If not, then you know it's something with the elimination. There's always that small chance that it happened at the same time, but is not related.
A byproduct of combustion is H2O. Watch any of the Ford modular series engines start up on a cold morning, the water drips out of the tail pipes. My moms truck leaves a little puddle.
As long as your coolant isn't going anywhere, everything is running well, and it goes away when it warms up, I wouldn't worry about it.
Could be you FAIV (Fast air idle valve) leaking coolant into your throttle body. Check the gasket right above where the coolant lines connect to the throttle body, it could be bad.:dsm:
If all it is is water that's coming out, then like stated above, don't worry about it. I used to have a fox body 5.0, and in the morning that would drip quite a bit at idle too. Granted it was pig rich, but was perfect other than that. If the smoke smells sweet or sugary, then it is definitely coolant. If not, then it's something else.
Ok does it do it when its hot outside to because it could just be moisture left over in the exhaust.
Yeah mine does that. I got freaked out one time when it happened and I had to pull over to make sure nothing was wrong. I got out checked for any smells and then gave it a little gas and water spat out. I was relieved to say the least.
Yup, my old 5.0 did that too.
Well, atleast thats what I noticed before I cut my tailpipes off! :D
