squeaks when i turn?
ryu
489
Feb 6, 2003
never never land, Maryland
i think my p/s belts are slipping or something...when i hit the lock of my turn it squeaks. and if i hold it does one of the two... while moving, chirp chirp chirp (like i have fat new tires) or a squeeeeaakkk...sorda long and most deff loud. :thumbdown do any of you guys have the same prob? :confused:
yea dude its your p/s belt i had the same problem and i didnt know what it was and i was racing this kid one day and i hit rev limiter in 2nd and the belt flew off and when i put a new one on i made it rather tight and it doesnt squeel any more just make sure u keep it rather tight
its not hard at all there is tensioner pully just make it loose take the old one off and put the new one on and make it rather tight
can i make a visual inspection of the belt? if the belt is good, can i just tighten the tension pully?thanks! :thumb:
Yes, do a visual inspection. If it appears to be OK, tighten it a little and that should solve the problem. If it starts squeaking after a relatively short period of time, I would replace the belt because it is most likely on its way out. Oh, and you aren't supposed to hit the steering locks, cars don't like that.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
