squeaking
take off the top of the timing belt cover and see if you can listen a little closer (jsut be careful not to get your fingers cut off by the cam gears. If you still cant figure it out see if a mechanics stephiscope (sp?) can help you figure out the location a little better. You should be able to get one at autozone or murrays. If there is any question about anything by your timing belt; tensioners, balance shafts, water pump, etc, then you should change it just for the insurance and peace of mind it gives you.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
