Sputter at 3k
THEKILLERWHALE
90
Mar 28, 2011
San Diego, California
When cruising (usually around 3k Rpms) it sputters a bit. Only when giving it gas. With no gas or throttle, no problem. Just sounds like minor backfires repeatedly.
Doesn't seem to give me
Any problems, just checking
Still have no problems accelerating or at any other speeds/Rpms. If I'm accelerating it doesn't even do it at all, just when I'm cruising through town just kind of holding my speed.
I dont have tuning software hooked up yet, still trying to fix my obd2 port so dsmlink will connect.
Just wondering if anybody knew the problem (and/or fix) off the top of there head and maybe I could do something about it before I got dsmlink working.
Thanks guys
I hanged my wires and that helped. I i didn't change the plugs cause they were new themselves. If it was a plug wouldnt it happen all the time and not just at a low Rpm?
You're right that if it was plugs, misfiring would be all the time or sporadic, and unlikely to be rpm based. Are you sure you aren't seeing it under heavy acceleration? Though if hanging your plug wires helps, I'd check the plug wires and their contacts out.
It still seems a bit odd to me, because I would have originally looked for a boost leak with what you described, not plugs or plug wires... Just in case, you might also make sure all of your pipes are tightened down, especially if you've worked on them recently. Who knows, you might have more than one thing going on.
