Spec Stage 2+ Chatter
PieEyedPiper
DSM Wiseman
5,580
65
Nov 13, 2004
North Bay Area, California
Firstly I'd like to thank the guys at "the speed factor" for doing business with me. The Spec Stage 2+ is a phenomenal device. The pedal pressure is perfect and the engagment is firm and precise. Definitely a quick biter!
But I'm experienceing a lot of chatter when going in and out of first and second gear. Is this normal for a clutch of this design? My mechanic told me the clutch is essentially a "paddle" clutch, which I'm sure is something like "puck" in V8 terms. Anyways, he's kinda right the design is aggressive while still maintaining a good level of streetability.
Is my chatter a result of an aggressive clutch? is there something I can do to help the issue? and most important is it detrimental to my crank/drivetrain to ahve it chatter (lots) almost everytime I'm in and out of first gear?
Thanks!
My Spec stage 3 does the same thing, only on deceleration though. So I just put it in neutral and then I don't hear it. :)
How long have you ahd yoru clutch? mines been broken in now for at least 1000 miles. I keeping hoping the chatter will just go away one day..
I'm positive such violent vibration can't be any good for my tranny/crank.
How many miles are on yours? I have over a 1000 on mine as well. I don't see how adjusting the pedal would affect it that much...Mine engages about 1/3 up from the floor I'd say, and my master is adjusted almost all the way out.
By now? probably 1200 - 1400 miles.
Well the thing was, the clutch was engaging nicely where it was, and i had about 2 inches of free play at the top too. Sounds good right?
Well I moved my floor mat to find out the stroke of my clutch was about 3 inches further than I had been previously utilizing.
I moved my mat out of the way and adjusted it further down. Now I have more freeplay uptop (meh) but it engages more smoothly. I believe it was a combination of that and the further break in that made my chatter dissipate into a once-in-a-while-if-i-slip-it-wrong kind of thing.
how slippable is the spec stage 3? its what im going with for my rebuild...
